On a Mustang GT.
I have a 99GT, The OEM MAF is a 4 pin setup and the wiring harness is a 4 wire setup. I recently picked up a MAF off of a 03 GT and turns out it is a 6 PIN MAF.
I notice that my stock MAF from 99' (4pin) only measures the air flow and the temp sensor is a seperat unit from the MAF housing. It seems in 03' they incorporated the temp sensor and the air flow sensor into one unit hence the extra 2 pins from 01 and up.
I am thinking that I can still use the 03 sensor (or I am out $30) depending on which pins on the housing go to which sensor. Does anyone know which pins go to which sensor? We are talking about the pins within the large female connector on the MAF housing.
