problem with an 06 Dodge Diesel
  • problem with an 06 Dodge Diesel
    Father inlaw has an o6 dodge diesel with standard tranny. When you are accelerating the truck just hesitates and bucks.....you pump the gas and it kicks it back in. So, like i said, you push on the gas and then it bucks like it gets no gas....and then it will kick back in.
    Maybe an electronic throttle or something?
    Semper Fi
    You may find your answer here, but if not: http://www.dieseltruckresource.com/
      Any codes? CES light?
      Could be any number of things. How many miles?
      Could be dirty fuel filter(been changed recently), sticking FCA, etc
        no idea. you remember crazy dave from around the corner at my old house? he says it is the throttle position sensor so we are gonna try that first.
        Semper Fi
          What throttle?
          Its a diesel. Theres a pedal position sensor(since its electric, no more cable) but there is no throttle body, lol.
          Does it idle fine otherwise? or just when starting off under load?
            What throttle?
            idles fine. just when driving.
            just ordered the throttle position sensor and it will be here tomorrow. I changed a tps out on my mustang but not a diesel......so now i am gonna google where it is and what to do. looks easy enough. 2 screws and unplug a connector.
            Semper Fi
              APPS is on the pedal on that truck. Did you test it or are you just throwing parts at this thing? because throwing parts at it is going to get expensive quickly
                Id have started with fuel pump/fuel filter... these motors can pull some fuel when the pump is bad but probably wont run.
                  So far the only thing I have done is call a buddy that has fixed a fuckload of vehicles and has always had the answer for me when working on stuff. I ordered a new tps for it today. it was less than $40 so that is where we will start.
                  Semper Fi
                    I worked on plenty of diesels on the barges and it is not acting like a fuel pump/filter at all. we shall see
                    Semper Fi
                      Fuel pumps are notorious on these trucks
                        well that will be my next thing to check if the tps doesnt work. I cant really do anything mechanical right now cuase of the surgery i just had but if it is easy enough i am gonna just talk my inlaw thru swapping it.
                        Semper Fi
                          fuel pump involves dropping the tank...it sucks. The key is to jump under the truck and see if you can at least hear it prime when turning the key on
                            good to know
                            Semper Fi
                              good to know
                              If you have to crawl under it to hear it ,its probably not working . Should be able to hear it with the door open/window down .
