Originally posted by Sickwindsor
Coyote Flow numbers?
Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by Sickwindsor View PostThe low lift exaust numbers and the dyno results I have skimmed thru.
I wouldn't call it a great N/A or Nitrous motor.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by Phuck Phace View PostOh wow, what did you make on a smaller tire?Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by 46Tbird View PostThere are a few all-motor coyotes with stock heads and cams running tens at 3600lbs.
You were saying....?Last edited by Torinoman; 11-27-2012, 05:14 PM.1971 Ford Torino - Time to go bigger and better.
If that is the case? I would like a .600 lift cam for the coyote to make good power up to 8500!
My goals are mostly bolt ones and cams in search of 480+.... hopefully 500 for fun.
In my 2950# race ready with driver car....it should be a hoot on track and probably the craziest thing around short of a trans am or GT1 car. Will be learning all I can about the new motor over the next few weeks.
Originally posted by aggie97 View PostI'd like to see you attempt to lift a coyote valve to .600" lift. You would need massive piston notches to even get close and you better understand valve event timing with the VVT screwing with you all the time.
Now I know what the limitations are. That was my main question.
Originally posted by Torinoman View PostStill only said not impressed by the FLOW NUMBERS, which is only a small piece of the equation
I would say enough airflow to achieve 450rw with untouched heads and cams at 300ci qualifies, but I'm all ears to hear what you think.When the government pays, the government controls.
Originally posted by Sickwindsor View PostWouldn't attempt it, wanted to see if it was possible.
