add a capacitor to the power lines on a msd
  • add a capacitor to the power lines on a msd
    MSD suggest it, anyone else use one, i added one last night and it's doing work. Parallel on the power wires.
    from MSD: The Noise Filter will prevent damage to the MSD during jump-starts and will keep a vehicle’s 12-volt line “clean” by removing any voltage and current surges that could interfere with the operation of some MSD accessories such as the Soft Touch Rev Control or the Two Step Module Selector. It is recommended that the Noise Filter be used on installations with the MSD 7 and 8 Series Igni*tions to prevent this interference.
    Be honest, even if it hurts.
    What micro-farad sized cap?!
    Do you have a link to it for wiring it up?
    ./ ____ _ _\.
    (]]]_ o _[[[)
    \o_FORD_o/
    |__|.....|__|
    God closes doors no man can open, God opens doors no man can close. Revelations 3:7-8
      I dont have a 7 or 8 box, so Im good to go without a cap.
        Been see a lota msd hate these days
        they call em Might Suddenly Die now
          msd tech support is a bunch of dbags.
            26K mfd
            http://www.msdignition.com/WorkArea/...id=15032386411
            I burnt up my MSD7AL a while back testing my shutoff switch with the car running, I didn't have the alternator output lead run to the battery side of the switch and when i shut off the switch (which just disconnected the battery at the time) it let the alternator go into over voltage without the load of the battery on the alternator. It fried my msd, my coil and the cap and rotor. I got a RMA from msd and it cost $27.50 to have it fixed. Needless to say, I thought MSD tech was kickass.
              a cap is cheap protection
              it protects a lot of electronic stuff in your car.
                from Cranecams old site
                FILTER CAPACITOR HOOKUP
                A filter capacitor on the 12 volt supply is recommended in
                applications where any of the following apply:
                • One or more solenoid valves are used drawing more
                than 10 amps total (measure with amp meter if
                unsure).
                • The ignition system power connections are not directly
                routed to the battery.
                • The battery is trunk mounted or more than 6 feet of
                wiring exists between the battery and ignition system
                (total of ground and +12 volt connections).
                Use a minimum 38,000 microfarad (uF) 16 volt capacitor
                such as Crane P/N 9000-0014. You can also use a
                Panasonic EEG-AA1E473FGE or EEG-AA1E683FHE
                capacitor with bracket MC51B3 available from Digi-Key (1-
                800-344-4539). Install the capacitor across the 12 volt
                supply (heavy red wire) and chassis ground in close proximity
                to the ignition system.
                http://www.cranecams.com/uploads/ins...9000-9520_.pdf
                  unsure).
                  Thanks.
                  ./ ____ _ _\.
                  (]]]_ o _[[[)
                  \o_FORD_o/
                  |__|.....|__|
                    had a huge stereo, tv/dvd/FAST/MSD/etc etc, never had any problems with any type of eletronics dying... Your post specifically says MSD 7 and 8 boxes need that, I have Digital 6s (ie streetcar stuff)
