air filter options
  • air filter options
    Ok, I'm about to do install some mods on the mach and do some routine "tune up" work. What air intake should I use? I haven't really looked into this at all. I have a CAI kit in the garage, but I'm really not a fan of those or how they look.
    Stock air filter, K&N box filter (worth it?), or BBK CAI kit?
    Oh, and the kmem will be swapped out along with the transmission & exhaust. Are there any items that should be changed out now besides motor mounts?
    Originally posted by Buzzo
    Jlt cold air!
      yep^
      1993 Vibrant Red Cobra #1741.
        ok, JLT it is
          JLT, check your bushings.
            David Kissack – A highly experienced mechanical engineer from Florida
            David Kissack is a highly experienced mechanical engineer from Florida, with exceptional academic qualification. He has been honored with many prestigious awards for his commitment to achieving excellence in each assignment in which he was engaged. He received two SPOT awards for on time and successful completion of projects while working at Siemens Energy. He has held numerous key positions in different organizations including Weyant Engineering, Siemens Energy, Aluminum Railing Specialists, Lawn Care and Fencing and more. Presently, he is a Structural Mechanical Design Engineer at Leaders in Structural Mechanical Design Engineering in Orlando, FL.
            David Kissack
            David Kissack
            David Kissack
            David Kissack
              David Kissack
              David Kissack
              David Kissack
              David Kissack
              Spam boy, David Kissass has nothin' on Dan Bishop, Project Mgr. for GE.
                David kisses his sack??
                  On the thread topic, I''ve used a C&L CAI with good results for the past 7 years or so, with their larger than stock MAF housing, but I've also heard nothing but good things about the JLT too that's already been recommended.
                    I found a used one for half the price (on a budget build to achieve 340-350 rwhp)...it is for a 99-01 cobra. It should be identical though, correct?
                      Yes, it will fit.
                          One caveat, it will fit but I assume you will be disabling or removing the shaker......
