Transmission Issue
  • Transmission Issue
    Yup, it was bound to happen sooner or later. At 89,XXX miles it was time for the transmission/clutch to start wearing out.
    Anyways I am kind of at a loss though and some are saying ToB, pilot, and pivot ball but I have no idea, yeah I will need to replace them all to be on the safe side but I'd like to know what exactly is it coming from. I am horrible with diagnosing transmission problems as they are right there with wiring, I hate them.
    What do you guys suspect is the problem?
    Why not describe what it's doing, can't tell shit from the vid.
      Well with the clutch out it make a screeching sound, when the clutch is in the sound is there but not nearly as bad. My '96 had a bad ToB but didn't sound like this, then again my '96 was in alot worse shape with the ToB
        Pilot bearing
          Bad throw out bearing usually causes a vibration, however it really doesn't matter. If you are getting a new clutch you should replace the slave/throw out bearing and pilot at the same time as well as the rear main seal.
            Yep agree+ surface flywheel
