One of the front seat bolts came loose on my 92 coupe. Any suggestions on repairing or replacing the bolt? I can't get my hand in there to get the bolt through the hole and put the screw on.
Front seat bolt came loose on 92 Coupe
The front bolt is part of the floorboard, only the nut comes off.
If the bolt is loose your floorboard is cracked/torn/rusted out. Weld it back together or replace the floorboards.
We hold these Truths to be self-evident, that all Men are created equal, that they are endowed by their Creator with certain unalienable Rights, that among these are Life, Liberty and the the pursuit of happiness......, that whenever any Form of Government becomes destructive to these Ends, it is the Right of the People to alter or to abolish it, and to institute new Government,
.....I'm posting from my phone, probably while driving. Expect typoes.......
Yep, typical fox problem. It happens to all of them. Like it was suggested just weld a new stud in there."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
I've been trying to get the bolt in the hole, the problem is I can't get my hand far enough in to start the bolt. I think once the bolt is in place I should be able to tighten the nut. Any suggestions on how to get the bolt started?
Will JBL Weld work?
Originally posted by mustvid View PostI've been trying to get the bolt in the hole, the problem is I can't get my hand far enough in to start the bolt. I think once the bolt is in place I should be able to tighten the nut. Any suggestions on how to get the bolt started?
Will JBL Weld work?
when we were doing police car installs and had to keep breaking out the front seat bolts, we just got a box of replacements at grainger and used some good flat washers with it. it took a 2lb sledge and some good sized punches to get the old ones out.. but its completely possible
can't you slide the seat to give you a better attack angle?
Originally posted by mustvid View PostHow do weld a new stud in when it is inside the seat rail?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
