TFS Stage 2 Cam Valvetrain noise
  • TFS Stage 2 Cam Valvetrain noise
    Well my car sounds like a sewing machine when its at idle & more throttle faster it sounds.
    Installing 1.6 Billet Erson Rockers to see if this helps. But im thinking maybe the stock Valve Springs are not letting the lifters pump up. I dont hear it on the Passenger side but its loud on drivers side
    Heads are GT40P heads on stock springs. This noise was with stock rockers. Gonna change out rockers & report back. But any other suggestions
    GOD BLESS TEXAS
    August Landscaping
    214-779-7278
    Seb's high class.
    He'll mow your grass.
    He'll kick your ass.
    He'll piss in a glass!
    I have limited knowledge on those cams, but aren't you dealing with over .550 lift on the exhaust side? I think that you might be really close to having clearance issues with the GT40 heads. I'd be really careful.
    I'm thinking some spring-bind at least?
      thinkin about this.....sounds like the springs may need a change........alot lift for stock springs
        If you are running stock explorer valve springs, I believe that would cause some float at higher rpms due to the lift that that cam has.
        The ticking could be anthing from a dead lifer to a loose or broken rocker.
          Baron def not a broken rocker. Got it all tore down & nothing seemed wrong with the Rockers. They all where tight & not moving. Just not sure if its a lifter or Valve Springs binding up. I think im gonna have to change out the Valve springs on these heads at the very least as I know the stock GT40P Valve springs cant live very long with this cam in it. That is if its a TFS Stage 2 cam. I will say it doesnt lope very hard at all to have a 112 lope Sep & cam being so big.
          Has anyone ever changed Valve Springs with Heads still on the car. I researched the net & came up with this http://sbftech.com/index.php?topic=15607.0
          GOD BLESS TEXAS
          August Landscaping
          214-779-7278
          Seb's high class.
            Have you checked the preload on the lifters? that will cause noise if it is set up wrong.
              Ok pulled the lower Intake. Im thinking im going to put these AFR 165s I have on it. I called AFR & they said their heads come with Valve Spings good to 135 Seat Pressure. The TFS Stage 2 calls for 130 Seat Pressure. If this is in fact a TFS Stage 2 cam its amazing it was running with the stock GT40P Springs, Anyways heads are coming as soon as I finishing typing this.
              Question?
              Can I reuse the GT40 Head Gaskets or should I get some new Head Gaskets & if so which kind for AFR 165 Heads that will see 150 Shot
              GOD BLESS TEXAS
              August Landscaping
              214-779-7278
              Seb's high class.
                Never re use head gaskets
                1997 viper gts
                1986 turbo mustang
                1987 Buick grand national
                1972 nova
                  is it just me or does it look like someone coated the lifter valley, but most of it has flaked off?
                    Yeah I think your right Baron, It does look that way. They had some metal flake paint on the Alt Bracket. Some of this shit was way Half assed. I need to post up pics of the transmisson support Bracket, The starter makes a awful noise when you go to start it like the starter & flywheel arent lined up. Like a old Chevy started that isnt shimmed
                    Question?
                    What head gaskets then for AFR Heads & 150 shot
                    GOD BLESS TEXAS
                    August Landscaping
                    214-779-7278
                    Seb's high class.
                      Question?
                      I hate to be the bearer of bad news, but if there are paint flakes floating around in that motor, it wont last very long. You might think about tearing it all the way down, hot tanking it, new oil pimp, lifters, rings and bearings.
                        Question?
                          It was cleaned off previous to install from looking at it. It appears up close someone tried cleaning it off
                          GOD BLESS TEXAS
                          August Landscaping
                          214-779-7278
                          Seb's high class.
                            Originally posted by BigDumbRedneck View Post
                            Thank you man! Way cheaper then I thought! Wish a parts store carried them local
                            GOD BLESS TEXAS
                            August Landscaping
                            214-779-7278
                            Seb's high class.
                              Heads are off, Cleaning the block up tomorrow & gonna start prepping it for the new heads
                              GOD BLESS TEXAS
                              August Landscaping
                              214-779-7278
                              Seb's high class.
