So today I started my 92 fox body mustang and the car wont stay idling the rpm needle jumps up and down then the car dies out and has a hard time starting back up with little gas is there anyone that ran into this problem I already change the tps any help would be nice
Idle problem
 Is the A/C on when you try to start the car? I had an issue in my '98 where it would idle fine with the A/C off, but would hunt for idle and die as soon as I turned the A/C on. Turned out to be a vaccuum leak in the vent acctuator line, that only caused an issue when the A/C was on.
 I'd double and triple check for vaccuum leaks again, it's easy to miss something. How exactly are you checking for leaks?
