Cooling system temperature question..
  • Cooling system temperature question..
    91 explorer, burped the cooling system and a few big air bubbles came out.
    The method I used was sticking a funnel tight into the radiator filler neck, filling it halfway up the funnel with water and letting the engine idle until the thermostat opened. I had the heater on the whole time and it was blowing warm-hot air consistent with the temperature gauge readings.
    What i observed, was the temperature gauge would get 3/4 up then the thermostat would open and it would drop down to 1/4 stay there for around a minute and do it all over again. I did this with the funnel in about 5 times until no more bubbles surfaced through the water.
    So I put the cap on and went for a 10 minute cruise, thinking the system being under pressure would stabilize the wide range of temperature variance. It did the same thing, but the heater was blowing hot air the entire time.
    So when I got back to my house, I let it idle a few minutes until the gauge got to 3/4 and shut it off. Went and grabbed the fan clutch, it doesn't spin freely but it spins just like the one sitting in my garage. How tight are they suppose to be when warm? Keep in mind during all this I never once heard the fan howl like I'm used too on fan clutch cars.
    I reused the fan clutch from my old engine, which had cooling problems according to the guy I got the explorer from.
    My question is, Is this a case of a bad fan clutch, or sticking thermostat? The radiator cap is a ventable stant, but it has this issue cap on or off so I don't suspect that to be an issue.
    What do you guys think?
    Sounds like a thermostat to me. If the fan were failing and not drawing enough air the temp would not drop. The thermostats failed on explorers all the time. When I was at a dealer and we had the mail trucks in (4.0SOHC) we used STANTS as no other would last in that application.
      Uh, test the thermostat and see if it is bad. Pot, water, temp probe and a stove.
      Clutch fan has a thermostat of sorts to it also.
        I'll replace the thermostat today after work.
        Thanks.
          I'll take stat for $500 Alex!
            Changed the stat and re-burped the system. A BUNCH of air came out.
            Although it never got warm, above mid gauge, at idle.. Once I started crusing around it started doing the same crap again. Warm, cool, warm, cool.
            So I floored it, got to ~100mph in 4th, and it was fine after that. The gauge didn't move anymore it stayed put at about 1/3. Cruised at hwy speeds and city driving and even idled for a few minutes and it was fine.
            Not sure what was going on, the stat helped for sure but I guess I just needed to blow the soot out.
              The early 90's Fords just do that. I had a taurus that would fluctuate between 3/4 and 1/4 all day long., same with a contour and my past mustangs.
                All of my 3 foxes have never done this.
                But I figure its not a big deal. Just don't want to blow a head gasket or crack a head.
                  I have never had a fox era mustang, but I know my 96 jumped all over the place, hell even my current 96 will dance.
                    Mike buy one of these funnels and save yourself alot of headache in the future.
                    [ame]http://www.amazon.com/Lisle-24610-Spill-Free-Funnel/dp/B001A4EAV0[/ame]
                      http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
                      QFT, some of the best money you can spend to avoid headaches.
                      Originally posted by Sean88gt
                      As always, my criticisms should never be taken as if I wouldn't go balls deep in it.
