Well, at first my stretched cable was causing the trans to grind and not allow it to go into gear. I thought if I replaced the cable it would be good.
After the cable replacement, I can put it into gear. If I start releasing the clutch it will begin to move, but then the trans acts like it pops out and makes a terrible grinding noise like before.
Do I need to reset the stock "self-adjusting" quadrant, or would that not be the issue? The cable does seem to be pretty tight. If I can't fix this soon, I just want to do a t56 swap...I want one again.
