Coworker of mine is looking to get some work done on his 2002 Explorer.
Apparently the issue is somewhat common with these, so he is hoping to find a local mechanic with some experience to perform this work for him.
"Ours is exhibiting the rough 2 to 3 shift and reverse and throwing the solenoid B code all of which ‘should’ be resolved by replacing the solenoid block:
Here is the write up I found:
http://www.explorerforum.com/forums/...d.php?t=164055 "
He is in Carrollton, TX - The truck is just shifting hard, so he would be able to travel.
Please PM if you can do this work, I'll send his contact info.
Thanks
Thanks
