Ok, noticed it today coming home from work. There is a click noise when I press the clutch pedal in, almost to the floor. It isnt a constant clicking, only one solid click, then clicks again when Im about halfway letting off the clutch. Doesnt matter if im driving, stopped, or engine off, it clicks when the pedal is pushed all the way in.
I got home and looked at the cable and the pedal. As I pushed it in, it was more of a metalic click that appeared to come from the bellhousing. I had someone press the pedal while I laid under the car and watched the cable and fork move. It seems to "catch" a bit or step when the click occurs. Its definately coming from the bellhousing.
It didnt seem to affect the driving or transmission. Just clicked when clutch was depressed. Ideas on what it could be? Similar incidents? Thanks in advance.
