Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Tips on brake booster removal SN95 - DFW Mustangs
  • Tips on brake booster removal SN95
    I think the booster on my 95 Cobra took a dump so I'm going to verify my suspicions later today, and replace it if necessary. Any tips to make it easier?
    you need a lot of patience and a ratcheting wrench that has a swivel head. Like these.
    I just replaced the one in my 92 and went from the 4 banger pancake to the sn95 big booster. It sucked, but I got it in there. Yours should be a lot easier.
    Originally posted by stevo
    Stevo
      What size are the nuts?
        well... on my 92 they were 14mm, but the sn95 booster I got came with 12mm nuts.
        Stevo
          It would also be easier if you remove the seat, but not sure how much you want to do to get to it. I didn't remove my seat, and it took about 2.5-3 hours just to remove the booster... and a few more to install it but I had to use a BFH and a drill for the studs on the SN95 booster to fit.
          Stevo
            I did my swap a few years ago and I recall having to elongate(sp) the holes. I went from a v8 FOX booster to a '95 GT booster.
            sent from an htc EVO, the iCrap killer.
            --carlos
              All it takes is time.
                I don't remember being that hard when I pulled mined.. If I remember right the hardest part is getting the nuts off.. Its tight under the dash..
                  When I was younger it didn't seem to take so long. I do remember it not being very comfortable under the dash with the door sill in my back.
                    I don't think its the booster afterall. I noticed a loud hissing sound at lunch today. Opened the hood and the oil fill cap was off. That thing pulls a ton of vacuum, so I tightened the oil cap, and the noise went away. I hooked up a cacuum gauge and it showed about 14" at idle. Took off the oil fill cap and it drops to 9". That's why my brakes were pooped out. I threw the laptop on the car and put her in open loop. With the cap off it got super lean like 16.4 AFR and ran like crap. Cap back on and its at about 14.6. I hope that was all it is. I'm still driving the Lightning today so I really haven't taken the car on a road test. Felt ok in the driveway though.
                      Dude... that's no reason not to go buy the tools.
                      Stevo
                        Fwiw. A 93 cobra booster and sn 95 are the same in size and will both work on a fox. The 95 booster uses diff nuts and has a little bit off stud offset. Not that it matter in this thread but to all future sn95 swap foxes out their, now ya know.
                        One day at a time.
                          You early guys also have to pound a little on the tower.
                          I thin 91 and before correct me if I'm wrong.
