help , 5.4 main stud question
  • help , 5.4 main stud question
    so i just got my motor back from the machine shop, freshened up, honed, new rod bearings , piston rings, yada yada, ok so i was going to install the pick up tube and it just so happens that the extended main stud for the pick up tube is in the wrong spot, what do i do , can it be swap, then just re torque the two studs or does the whole torque sequence need to be redone?
    whats the best way to approach this problem , thanks
    its a 5.4 mod motor
    00 TT gt
    634 @10psi
    04 cobra
    560whp
    I would just take it out and torque it normal.
      as in do the whole sequence over , or just re torque the two studs
      00 TT gt
      634 @10psi
      04 cobra
      560whp
        I would just re torque the two.
          ok thanks guys
          00 TT gt
          634 @10psi
          04 cobra
          560whp
            Just torque the two. Sorry I wasn't clear.
