Battery Light Coming On??
  • Battery Light Coming On??
    I swear it's always something here lately....
    My battery light is now coming on, but it comes on then goes off and so on. It comes on after a few mins of driving but when I get on it goes off then comes back on.
    My battery & alternator are both less than 3 months old, I checked my battery and it's showing 90+% charged. This morning checked my voltage on the battery with the car on & off and everything is fine.
    What else could be causing this? It just started over the past few days
    Test the alternator and make sure it's not putting out any AC voltage.
      Alternator is probably got a bad regulator.
        Still having issues. I've had the battery & alternator load tested and both were fine. My battery light still comes on and I noticed yesterday when I had my air on high that when at a stop it slows down then speeds up when I drive. ??? WTF??
          bingo bango
            does your battery happen to be gel filled?
              nope
                belt?
                  belt?
                  Haven't checked that yet, how would I know if it's the belt?
                    Check the electrical connections make sure they are good.
                      If its cracked, weathered looking, loose, squealing, slipping or the inside is shiny. I just went and replaced the belt on my aunts car and it had one whole tooth gone
                        check the idler pulleys! worth a shot.. also check all your fuses
                          check alternator pig tail
                          also check the conection inside the alternator for the pigtail...
                          Originally posted by BoostedGT
                          I got one of them POS x275 88mm's sitting on the work bench. Come get it.
                          Originally posted by bigminz
                          Hell no. Have you seen most of these cars up close? Death traps at those speeds.
                            X2
                            04 GT
                            91 LX
                              OK, now I give up!
                              I installed my new PA Performance Alternator yesterday, upon removing the old one I found that a piece of the back of it had broke off. So after I installed the new one OF COURSE my battery light comes back on! I just don't get it
