Just curious if you guys think I will see a big difference is times in the 1/8 by changing the throttle body.. Current setup
306 forged pistons
F cam
30 pound injectors
65 mm throttle body with a 70 mm spacer
Performer heads
Preformer 2 intake
73 pro m mass air
4.10
With a c4 and 4k stall
I do have a 70 mm throttle body but it whistling so loud it's annoying..
Was told that the 65mm would be more throttle responsive on low rpms and the larger intake uptop would get the most. Current set up went an 8.10 with an 1.8 60ft and 86.5 mph
Next weekend will add aluminum driveshaft and trans brake solenoid.
306 forged pistons
F cam
30 pound injectors
Performer heads
Preformer 2 intake
73 pro m mass air
4.10
