I was told that the 8.8 should bolt right in,but when i started taking the 7.5 out i noticed it had the brake line fitting on the P/S rearend and the 8.8 doesnt have one at all, So what am I needing to do?Also the 8.8 has a extra set of brakets, what are they for and if not do i just cut them off or what? One more thing the 8.8 has a peice bolted around the top of the pinion and 2 block looking peices at the bottom, whats that for? Im going to try and post pics to show what im asking about.1st pic is the 7.5 and you know what the 2nd is
Need Help,8.8 replaceing 7.5 on 89 4banger to V8 coupe
ZO6: Thanks, Im going to get aftermarket control arms little later on for wheel hop. Woult it be better to use the shocks or control arms? Will i need to have them off or will they be okleft on there?I was thinking of something like a t fitting for the brake lines.If anyone has info please let me know.Ace Duce
I can't play in the deep end of the sandbox, that's where the leprechaun is and he tells me to burn things!
It had a lot of build up around it and I tried to clean it off the best I could. But the old lady was trying to start a argument and I just got a glance at it before I bailed. So it could have still had a junk around it and that's why I thought it was welded on. I check it out after work and if it goes on the 8.8 you'll be my new hero for the week.Ace Duce
they looked like they would hit if i hit a good bump or dip. so thats why im asking if they are ok and wont hit or if i need to cut them down cause they will hitAce Duce
Yes that's the ones for the quad shocks. I didn't know if they hit or not since I'm not hooking shocks up to them.But cool now that I know my buddy and I are going to throw it in tomorrow after work.Any tips on getting the springs in easy? Thanks to everyone for their help!!!!Originally posted by dumpycapri85 View PostDo you mean the quad shock brackets or something else ? If the bracket closest to the brake drum on each side is the one you mean they will not hit .Ace Duce
