I am installing the fuel system now, and have run into a little issue. When I put the pump like I want it, the Y-block is pointing towards the side of the car with one of the fittings pointing slightly frontwards. This is an issue since the sump faces the rear of the car, I have 90* fittings on both of the outlets (-8) so they dump towards the side of the car as well. My concern is the the hose will have to make a huge loop to get to the fittings and the furthest fitting will basically have almost done a 360* before it all said and done. I am considering adding some 90* fittings to both the Y-block/filter connection (to point the Y-block towards the rear of the car, and then another 90* for the outside fitting (and possibly and additional -10 90* to get the line going the right direction to makes it's way up to the engine bay.
Here is a picture of how I have it right now:
Here is a diagram of what the setup is like:
Here is what I am proposing:
I hesitate to add all these 90*'s since I doubt it is good for flow, but not sure of any other options.
