Has anyone done this job on a Kia Optima before? Looks like a sealed bearing that needs pressed out then the new one pressed in. Did a little search and there was talk of a pre-load tool needed for other Kias but unsure if it is needed for the Optima.
Front Wheel Bearing Kia Optima
Originally posted by MstangsBware View PostHas anyone done this job on a Kia Optima before? Looks like a sealed bearing that needs pressed out then the new one pressed in. Did a little search and there was talk of a pre-load tool needed for other Kias but unsure if it is needed for the Optima.
Originally posted by shumpertdavid View PostI assume its a basic bearing assembly, you remove steering knuckle, press out hub, remove snap ring or bearing retainer, press out bearing, and reverse procedure to Install. More or less...The only difference between a tax man and a taxidermist is that the taxidermist leaves the skin. -- Mark Twain
