Okay. This is getting ridiculous now.
Things I've tried (with no luck) to get my turbo lsx foxbody to run cool.
New waterpump
New thermostat (I've now tried 160, 187, no thermo)
Huge dual pass radiator with 3.8 Taurus fan
Moved trans cooler away from intercooler.
Installed pusher fan in front of intercooler
Installed remote filler neck at highest point in system
Heat wrapped the entire hot side of the turbo kit (including downpipe)
Made a turbo heat shield for the exhaust housing
Tried to burp the system every way I can think of (even bought a special funnel)
And I am probably missing a bunch of shit I've done in between.
Still won't run cool. Still steady cruises up to 230* and above with the a/c on and can barely maintain high 220's with the a/c off.
Only odd thing I've noticed throughout this process of possible interest is that the inside of cross over pipes is clean like new. It was like this when I pulled it off for the motor as well, but I kind of found it odd that in 800+ miles no carbon build up in the cross over pipes. Maybe because the pipes get so hot that the carbon gets baked off?
Also, I tried burping the air out with my radiator funnel and it started pushing water up and up (I was waiting for the the thermo to open), and then it appeared to start boiling over (fairly dramatically) all over the place. According the gauge it was only around 190* when this happened.
So I believe I've taken everyone's opinion, spent a couple of hundred bucks, and have accomplished jack shit. Ah, so much fun.
New waterpump
