How much power will I make??
  • #31
    is there an antenna?
    Big Rooster Racing
    1985 Mustang GT
    • #32
      3/4 Race cam?
      • #33
        does it have NAWS ?
        07 GT500
        05 SRT10
        88 turbocoupe T-bird
        93 Cobra
        86 coupe
        Ducati 848
        • #34
          Originally posted by mk5.0 View Post
          does it have naws ?
          lmfao!!!!
          certified deisel mechanic
          • #35
            14 Jigga Watts. If the Mr. Fusion works, at 88 mph you might get busted by the Time Cops. Then you can lay the "limp dick" excuse that the 3/4 race muffler bearings were
            2.73's and the counter rotating stroked crank was over torquing your 31 splined windshield
            wipers!
            • #36
              Originally posted by JMAC View Post
              3/4 Race cam?
              I still LMAO every time I see this.
              -Dustin
              '94 Cobra
              Coast High 408, AFR 205s,
              1-3/4" BBK LTs, Tremec TKO,
              ZA0 Tweecer Self Tune
              09 F250 KR
              10" lift, 38s
              • #37
                Its all going to come down to how much psi you have in your tires.
                • #38
                  637hp
                  • #39
                    Does it have "Go Fast" stickers, because without them we all know it will be just another slow Mustang! Got to have the stickers, there good for 200 rwhp!
                    • #40
                      I've got a whole load of stickers I've collected over the years, I'm pretty sure a hedman header, NOS, msd, accell, and Autometer (only if you want some serious power from your 5" monster Tach) sticker, will net you somewhere around an extra 500-600 rwhp is put in the right location and order on the car. Let me know if you need some extra power with your current combo and I'll put them in an envelope. I'd recommend installing them one at a time and following up each install with a dyno or dragstrip run so you can document what each "sticker power" is truly worth. I can even through in a Dynotune sticker, but only if you'll be using a dynotune dyno since it will net the most hp increase when used in conjunction with there products. Also you need to clean the surface the stickers will be applied to really well as the amount of proper adhesion could affect the hp transference.
                      • #41
                        Does the seat have the geto lean??
