question for the ford dealership parts guys
  • question for the ford dealership parts guys
    my dad has a 98 crown vic police interceptor that he uses as a back up car or when the weather is shitty. the rear end sags and after looking online he found out that they made taller springs for the later years to keep them from sagging. he said the springs he has now are E springs. later they made F and H springs, with H being the tallest. he can't find them in any auto parts stores because they dont have them listed with the E, F or H. all the ones they have apparently are the E height.
    i was wondering if someone could look up the proper part number or name for the springs i am talking about. also how much they are at the dealership
    thanks guys
    Just put some air shocks on it.
      costs too much, plus he only drives it every once in a while
        put a bunch of those cheapo twist in spring spacers on it.
          i have a pair of what i believe are "h" springs, trim tag shows H for the spring code, and the green tag on the spring shows, HAP with the part number starting with F8AC... let me know if these are what ya'll need.
            The springs that butt86 has show to be h springs. The new ford part number is 3w7z*5560*fa and list for about $105
              incoming pm
              thanks man
                big thanks to brandon(butt86), picked up a set from him yesterday evening. he bought them from his job and took them home and then i picked them up from his house since i got off of work after he did
                thanks again brandon
                  no problem, glad i could help out. hopefully they work out and do what ya'll wanted them to!
                    That would have been cheaper. Thats prob what I would have done.
                      Wrong.
                      You are only crutching worn springs. Let one air shock go bad and you have a very unsafe situation.
                      Do the job right.
                        The twist in spacers are as bad an idea as the air shocks. You squeeze some hard metal chunks into an already weak/failing spring and what you get is a broken spring.
                          got the rear springs installed, along with 4 new shocks and a new set of tires. rides waaay smoother now
                          hey brandon(butt86), do you guys have any H code springs for the front?
