Brand new 331 with TW 170 heads and a TF "R" intake. The engine fires right up, no valvetrain noise, no smoke, no odd noises, nada. lopes just like a TF Stg 2 cam should do, but...................................
This thing is pulling vacume like a MF'er from the PCV hole in the back of the intake and from the breather neck in the valve cover. If I unplug the hose from the filler neck to the throttle body at the throttle body it will suck my finger up to it tightly. If I unplug the PCV hose from the upper intake it still sucks like a cheap whore.
If I remove the PCV valve and let it vent or rather suck in air the car idles perfect at 850 rpm. It will go into gear without stalling, revs great, no smoke, and stays at a steady 192 degrees. As soon as I reconnect the PCV the idle goes up, the lopy cam smooths out, and it will die as soon as I put it goes in gear. It's also difficult to restart. If the hose is pulled off the PCV you can hear a hiss of air as the pressure in the crankcase is relieved. I'm stumped, so anyone have an idea?
Top ring is gapped at .020 and the second ring at .016. This is in a 1993 Coupe.
