1990 GT No Spark issue!!!!
  • 1990 GT No Spark issue!!!!
    I have a 1990 GT, new motor that has 1500 miles on it. I turned the corner the other day and it died, now I have no spark. I followed this troubleshooting post
    All the testing pointed to the distributor being the issue.
    When I turn the key on the fuel pump kicks on, the car turns over with ease, I have pressure to the rails, I replaced the original coil and TFI, along with the distributor. I am at my wits end!! Any help would be greatly appreciated.
    Ground
    GOD BLESS TEXAS
    August Landscaping
    214-779-7278
    Seb's high class.
    He'll mow your grass.
    He'll kick your ass.
    He'll piss in a glass!
      When you say replaced, are you talking new, or used? If new, I am with SEB, check your grounds.
        Yes I replaced it with new stuff, and which ground where? Thanks!!
          I checked the ground wires coming off the driver side head and the two on the timing cover .....nothing out of the ordinary with them. I did unhook my battery over night to try and get rid of the check engine light but the light does not turn off when I try to start it.......
            where did you get the TFI? I have had ignition modules be bad straight out of the box. I have them tested in front of me at the parts store multiple times before I buy. Had one that drove me nuts. I brought it back and they tested it and it passed. I was like "do it again"
            on the third time once it heated up, it failed.
              I picked it up from Advance....
                I'd have it tested
                  I'd have it tested
                  Or throw that shit in the trash and get a motorcraft part.
                    This!
                      Did stab a new dizzy in it also? Brand?
                      sent from an htc EVO, the iCrap killer.
                      --carlos
                        Yes stabbed a new dizzy...just a stock motorcraft......as for the tfi had it tested and it tested fine....the one I pulled off of there was a knock off and I bought the car from a guy a Latemodelresto...lol.....I put a timing light on it to see if it would light off and it wouldnt....checked and I have power going to the tfi and the coil......just waiting to get my code reader so I can figure out what the check engine light is for......thanks again for any help
                          Gonna put my money on the pick up coil(stator) inside the dizzy.
                          --carlos
                            I would have gone there too, but a new dizzy should have a new pickup coil.
                              I stabbed a new MSD in and it had a bad pick up coil in it.
                              --carlos
