4V Cam ID help please!
  • 4V Cam ID help please!
    Cams are in a '04 Cobra. Upper cam on the driver side is habd scribed as follows...
    106-462-9LI
    CC
    VD 3031
    -09
    Any ideas?
    It's a comp PN, call them and give them the info and they should be able to get you what you need.
      I talked to Paul and he said the same thing. If the part number reads true to specs, these things are huge. The car does sound like a pro-stock.
        yo clifton, I didnt have time to call comp. I still believe the 462 is lift, I found a part # SIMILAR to whats scribed on the cam.(#106260) http://www.compperformancegroupstore...ode=106-CAMXER
        also, sometimes other numbers can be found behind the cam sprockets
          What mods does the cobra have? (completely unhelpful I know lol)
