I have a set of Windsor sr. Heads with triple spring. I'll be running a F-303 cam with a set 1.72 rocker. And was going to use a stock short block(stock trw pistons). I was wondering if I had to fly cut the pistons or could I just ruin what I got? 2.02 intake valve 1.60 exhaust valve. Would my piston to valve clearance be ok?
Piston to valve clearance??
.544 lift w/ 2.02 valve? To my knowledge that will not clear.
I ran an f303 w/ 1.72s w/ stock heads and pistons, theyre slightly fly cut already, and it cleared fine, but you have different heads AND a 2.02 valve.
Either way, checking for piston valve clearance on ANY combination of parts is 100% Protocal IMO. You never know! So always clay them or do a hand turn. Never just "trust it".
There will be people that say get an old 2.02 valve and glue some sand paper to it and throw it in a drill to do a "DIY" fly cut, this WILL work but you CAN fuck it up in a hurry and burn/cut a hole in the piston top, they are thin to begin with.
That being said, most small block chevy heads have 2.02 valves and be careful.
I'm running AFR 185s with 2.02 Valves, a F cam and Ford Motorsport 1.7 Roller Rockers in my 306, but I have the Keith Black pistons with valve reliefs in them. I can't remember exacly how much clearance I had when I clayed my pistons for clearance, but it wasn't that much. So at a minimum check, but I'm pretty sure you would have to fly cut the pistons.
Originally posted by uglydogo View PostI have a set of Windsor sr. Heads with triple spring. I'll be running a F-303 cam with a set 1.72 rocker. And was going to use a stock short block(stock trw pistons). I was wondering if I had to fly cut the pistons or could I just ruin what I got? 2.02 intake valve 1.60 exhaust valve. Would my piston to valve clearance be ok?sigpic
Originally posted by R3_82GT View PostI'm running AFR 185s with 2.02 Valves, a F cam and Ford Motorsport 1.7 Roller Rockers in my 306, but I have the Keith Black pistons with valve reliefs in them. I can't remember exacly how much clearance I had when I clayed my pistons for clearance, but it wasn't that much. So at a minimum check, but I'm pretty sure you would have to fly cut the pistons.sigpic
Originally posted by 91CoupeMike View Post.544 lift w/ 2.02 valve? To my knowledge that will not clear.
That being said, most small block chevy heads have 2.02 valves and be careful.sigpic
Originally posted by 91CoupeMike View PostIve seen it in other threads, I personally wouldn't do it, for the fact that I would completely trash the the piston lol. It works just has a uneeded level of sketchyness.sigpic
Originally posted by fordracer2 View PostHey when you doin this H/C/I swap? Do you have any of the parts yet?
Oh yeah, and the motor mounts for my aje.
My rear end in the car is the SUCK right now, I have a 8.8 axle housing, new gears, 31 spline carrier w/ carbon clutches and weld in torque box plates. I need 31 spline 4 lug axles and that will be a done deal. I need to get the rear end built, boxes welded and order some tubular control arms and I'll be set.
My control arms started popping since I lowered it and the last thing I want to do is throw 70-90 more hp to the torque boxes and rip the dog doo doo out of them.
Been working 50 hours last few weeks and doesn't look like I'll be easing up anytime soon, making money for the parts but no time to work on the car! Plus I have another project for a daily driver I'm working on too.
Brodix 5.0st r, anderson b25, systemax, accufab race 70mm, 90mm lightning maf, 3.5in power pipe, bbk ceramic long tubes, x pipe, spin tech super pro streets.. Should be a nasty little car. The b25 should love some nitrous so I forsee a 100+ shot.Last edited by 91CoupeMike; 06-02-2012, 08:40 AM.
Thank guys for all the info!! I have a set of dss pistons that have huge two valve reliefs. I would have to buy a set of rods for them (floating wrist pins). But whatever it takes. I really want a nice sounding motor. That has know issues right off the bat.
Originally posted by uglydogo View PostThank guys for all the info!! I have a set of dss pistons that have huge two valve reliefs. I would have to buy a set of rods for them (floating wrist pins). But whatever it takes. I really want a nice sounding motor. That has know issues right off the bat.I didn't build that motor that's just the way I bought it. Lol I broke a valve spring or two.
The max lift on the cam does not have everything to do with pvc its the duration and ramp rates that cause issues. The piston will be at the bottom of the cylinder when the valve will be at its furthest. there are a few people that havent has problems with similar specs with those heads but its highly unlikely with the 2.02. All you can do is put it in, compress the head gasket and check. All motors are different.
Edit: somewhere up above i saw tw heads and forgot he was talking about windsor sr headsLast edited by FoxBodyNick; 06-02-2012, 09:51 AM.1993 Vibrant Red Cobra #1741.
Originally posted by 91CoupeMike View PostI have all the parts, even the cam degree kit. What's holding me back is head bolts, header bolts and all the gaskets. Been shopping around for the best prices on them. So far rock auto is the cheapest.
Make sure those torque boxes are lined up perfectly before you weld them up. I did the UPR boxes that are bolt in/weld in that way i bolted them in left them a little lose installed the lowers then tightened and welded them checking alignment as i went. I can rebuild your traction loc for you for nothing (time permitted) if you can not. I have done a few including my own with the Kevlar kit it works good (see my sig pic). That is a good combo of parts you got its gonna run good. Some of the people that give you shit about your car won't have anything to say after that. wait, no they still will lol.
Brodix 5.0st r, anderson b25, systemax, accufab race 70mm, 90mm lightning maf, 3.5in power pipe, bbk ceramic long tubes, x pipe, spin tech super pro streets.. Should be a nasty little car. The b25 should love some nitrous so I forsee a 100+ shot.sigpic
