Auto Meter Electric Temperature Gauge
  • Auto Meter Electric Temperature Gauge
    I forgot......Does the needle go to " 0" or to the bottom of the gauge when the key is turned off and the motor is HOT. I think I may have a gauge problem, but I can't remember what the gauge did when I installed it years ago. I think my gauge is measuring about 20 degrees too hot. Anybody remember ? Thanks.
    electric gauges should go to 0 when they are turned off, mechanical obviously do not turn off
      Electric Temp gauge
      Thats what I thought. Mine goes down to either 120 or sometimes 150. My temp sensor that turns on the electric fan is set to come on at 190 degrees. The gauge shows 210 degrees when the fan comes on. I vote bad gauge. What do you think ?
        You didn't put Teflon tape on the fitting by any chance did you ?
