I've got a few questions about pulling this engine from the top.
1. Should I leave the trans (auto) connected or unbolt it first?
If I could pull the engine without removing the Y-pipe and drive shaft that
would be nice.
2. There are no lift tabs on this engine. Do I need to remove the intake and
use a lower intake bolt hole to attach a chain? Of is there a known better
way?
3. I'm guessing I'll need a power steering pulley puller to remove the pump/
front acc. bracket.
Thanks for any info.
would be nice.
way?
front acc. bracket.
