After driving roughly 350 miles so far on the new build, I am getting a lot of crankcase oil odor in the passenger compartment. In all fairness I drive mostly with the top down and the breathers are located right infront of the door hinges in the fenderwells. Like this.
That pump above the breather is on a relay and hobbs to come on at 3lbs of boost to pull a vacuum on the crankcase.
There is a breather on the other side in the same place but it is always open.
There is no PVC, only the two -12an lines to two breathers.
Here is an idea.
Move the setup to the rear. Connect the two valve covers together then a -16an to the rear split to two -12an. One going to the pump and the other to the single open breather. I think putting a check valve inline on the single open one will give me better results when the pump comes on.
The plan would be to pull the fuel tank (need to fix the vent anyways), drain it and get a bracket welded for the pump and breathers.
Thoughts, opinions?
Here is an idea.
Thoughts, opinions?
