Alright thanks, I'll try alm the above and let y'all know what happens.
Problems with 2003 cobra
I have built multiple 03-04 Cobras for serious Road Race applications. NO POPPING Sounds. If it is a straight line when it happens, chances are it is not the steering shaft. Your best bet is to check every bolt on the front end (and bushings) and make sure they are not loose....and torqued to spec. It would take you less then an hour to figure out where it is coming from. Suspensions don't "pop" unless there is an issue."Racing is life.....everything else is just waiting" - Steve McQueen
Originally posted by 03shadow4v View PostWhen you turning up the boost on your twin leaf blower setup ?440-RWHP, 400-TQ, 6psi
7.4 @ 93 mph 1.7 60ft
