Bear (Sp) Brake up grade for Fox Mustang
  • Bear (Sp) Brake up grade for Fox Mustang
    I picked up a set of the Bear brakes for the front of a Foxbody Mustang. This is the kit that uses late model Corvette brakes and has a re machined rotor that has been re drilled to 4 bolt pattern. I have the hubs and the welded up spindols too. Is this an OK set up, or is a lot of work for a very little gain. I also got the Cougar bigger 4 lug drums and brakes for the rear. Anyone ever do this swap ?
    Should have just done the SN95 Cobra swap. Cheaper, get 5 lugs, 4 wheel disc. Who wants corvette parts on their mustang??
    Doug
    90 LX Coupe 5.0
    90 7up Vert. 5.0
      This
      86 SVO - Sold
      '03 F150 Supercrew - Sold
      01 TJ - new toy - Sold
      65 F100 (460 + C6) - Sold
        I know that would have been better, but I already had a built 4 bolt rear end and a new set of 4 bolt wheels.
          Stock brakes with hawk pads, and a prop valve.
            That changes things, but you're gonna spend money either way. 5 bolt is better than 4 in every way.
            Tough choice.
            86 SVO - Sold
              Better than stock, but won't touch 4 wheel discs with the same pads.
                That's cool. You might want to upgrade the m/c too for the larger calipers.
                Doug
                90 LX Coupe 5.0
                90 7up Vert. 5.0
