Whats the chance of that happening? I ask because the 302 had a noisy lifter issue before I swapped in new lifters. I ran it about 30 mins with good (50psi) oil pressure. Ended up pulling the heads and the car sat for a couple months up till now. Bolted a set of stock heads on and tightened the rockers down and one didn't snug down on the pushrod which happens to be on the same side that was noisy before. I'm at a crossroads since I lack the upper intake, and front accessories from having the motor done or pull it down and check the cam. 30mins of run time suffient? 2months sitting play a role in this?
Wiped out cam lobe in roller motor?
I wouldn't think the cam would go flat on a roller motor. I'd imagine the lifter is the problem, swap it with another and see if the problem stays in the same place or moves with the lifter.
Hope that helps.
Could also be that it's in the event of a closed valve.
Originally posted by 4EyedTurd View PostWhats the chance of that happening? I ask because the 302 had a noisy lifter issue before I swapped in new lifters. I ran it about 30 mins with good (50psi) oil pressure. Ended up pulling the heads and the car sat for a couple months up till now. Bolted a set of stock heads on and tightened the rockers down and one didn't snug down on the pushrod which happens to be on the same side that was noisy before. I'm at a crossroads since I lack the upper intake, and front accessories from having the motor done or pull it down and check the cam. 30mins of run time suffient? 2months sitting play a role in this?
Originally posted by racrguy View PostI'm not sure about roller cams, but with a flat tappet it can go flat in a matter of seconds.
I have also seen all the dog bones break and that let the roller lifters spin causing you know what...awesome carnage
what weight oil is in it now ?Vortex rear stand $75
8.8 410s. $50
**SKAGG NASTY**
1990 Foxbody GT for that ass
114 door
13 FX2 White 5.0
a lifter could have lost it's oil
[QUOTE=Txstang1;651571]what weight oil is in it now ?[/QUOTE
use a 1/4" socket taped to a extension and a drill to turn the oil pump and get oil pressure, crank the motor over a few times while it has oil pressure, see if that fixes the lifter.Don't worry about what you can't change.
Be honest, even if it hurts.
Originally posted by 4EyedTurd View Post10w-30
I'll try priming the oil
I think if you run thick oil the lifters get used to/worn to that oil and a then they don't like a lighter weight oil. That's all I could figure with my situation.Vortex rear stand $75
8.8 410s. $50
**SKAGG NASTY**
114 door
13 FX2 White 5.0
Originally posted by 4EyedTurd View PostGot in this morning and get outside to prime the oil system and manage to drop the oil pump drive rod into the oil pan. Fucking glorious, days like today make me question why I work on stuff
Sorry about your luck, I have done shit like that before and you just got to step back for a while and collect yourself and not tear something up in rage
Use a magnetic pick-up tool and a bright led flashlight and try to get it out
Follow the above advice step by step and maybe smoke a fatty too.Vortex rear stand $75
8.8 410s. $50
**SKAGG NASTY**
114 door
13 FX2 White 5.0
Originally posted by 91CoupeMike View PostI've put the trans in and had it ready to go, got in to Start the car and go for a drive when I saw my block plate sitting in the back seat.
I was like.. !!!!Vortex rear stand $75
8.8 410s. $50
**SKAGG NASTY**
114 door
13 FX2 White 5.0
