Have a 70 mm throttle body that is whistling like crazy. I was told you can drill a small hole in the throttle body blade. And what size hole should I drill this hole. I put a 65mm on it and went away.
Bbk 70 mm throttle body
Originally posted by juic3d View PostHave a 70 mm throttle body that is whistling like crazy. I was told you can drill a small hole in the throttle body blade. And what size hole should I drill this hole. I put a 65mm on it and went away.--carlos
