I need to know the size and thread of the bolts. I misplaced mine and need some for my engine stand. I got a 302 block and where I can get some
Bellhousing to Engine Bolts
302 headbolts
they worked in mineDon't worry about what you can't change.
Be honest, even if it hurts.
Yep, 7/16 dia. by 14 pitch. Lenght will vary with bellhousing and bolt location.
Just an FYI, the 2 top most bolts need to be short. If you ever need to pull the bellhousing off with the motor sill in the car and the top 2 bolts are long you won't be able to get them out 'cause the will hit the firewall.
Therefore you can't remove the bellhousing.
Experience is a great teacher
Most hardware / parthouses stores have them.
