4 cyc Conversion Coupe Fuel Pump not priming
  • 4 cyc Conversion Coupe Fuel Pump not priming
    Im getting no power to my fuel pump. What do I need to check first before assuming the worst that my fuel pump is bad. Im thinking maybe a relay or solinoid, Just dont know where to look
    Car is a 92 Coupe with 5.0 motor
    GOD BLESS TEXAS
    August Landscaping
    214-779-7278
    Seb's high class.
    He'll mow your grass.
    He'll kick your ass.
    He'll piss in a glass!
    There is a relay under the drivers seat.
      What year eec harnes did you use? I ran into this not to long ago except I tried to use a 91+ harness on a 88 coupe
        I checked there & there are two relays under the mass air flow sensor. Im hoping one of these two are it. But not sure how to test the relays to make sure its them
        GOD BLESS TEXAS
        August Landscaping
        214-779-7278
        Seb's high class.
          To be honest. I dont know! Is there somewhere I can look to see what harness is was.
          The car ran fine when I parked it 4 days ago. Now It just turns & fuel pump doesnt prime
          GOD BLESS TEXAS
          August Landscaping
          214-779-7278
          Seb's high class.
            You saying the pump turns but doesn't pump shit?
            Alldata showing the pump relay is on right shock tower for a 4 cyl car, called integrated relay control module. Sounds to me like the harness has been changed.
              Here is a pic of a relay! Not sure what im looking at. But want to make sure I have the correct relay for the fuel pump
              GOD BLESS TEXAS
              August Landscaping
              214-779-7278
              Seb's high class.
                No power? Did you check the inertia switch?
                  Yes its pushed down, Tried it up & down! Nothing
                  GOD BLESS TEXAS
                  August Landscaping
                  214-779-7278
                  Seb's high class.
                    Im about to drop the tank, & replace the fuel pump. I have a extra pump here anyways
                    GOD BLESS TEXAS
                    August Landscaping
                    214-779-7278
                    Seb's high class.
                      Ok im gonna drop the tank & replace the fuel pump. Will touch base on if it fixed the problem or not!
                      GOD BLESS TEXAS
                      August Landscaping
                      214-779-7278
                      Seb's high class.
                        Yes they also put them under the mass air meter. I would try those first, I have some horror stories about that little shit of a part. I have had to use a hair tie to make it connect correctly and make it home. They are under 20.00, and I suggest going to napa or carquest for those. Autozone, and orileys were junk out of the box.
                        2005 M3 Vert with TSW rims
                        2012 Ford Edge
                          or just go to a junk yard and get some for free...
                            Ok well update! Went out this morning & dropped the tank & had a spare Fuel pump in the garage. Took me all of 15 mins to drop the tank,Well installed the spare fuel pump. Still wont fire. Just turns & turns!
                            I dont hear the fuel pump priming at all. Gonna go replace both relays under the Mass Air meter & see if this fixes it. KNOCK ON WOOD
                            GOD BLESS TEXAS
                            August Landscaping
                            214-779-7278
                            Seb's high class.
                              Did you replace the Fuel pump relay?
                              2012 Ford Edge
