I recently bought a 93 LX that had a white-faced gauge kit installed by the previous owner. The car appears to idle at <500rpm, the speedo is off by 10-15mph, & the Oil pressure is so high you can barely see the needle. The other gauges appear to be right, but considering how out of whack the above are I have little faith that they are very accurate either.
Is there a recalibration procedure for these? I realize they are not terribly accurate to begin with, but I would like them to be as realistic as possible. I suspect that "recalibration" will simply involve putting a known resistance (and therefore current flow) through the gauge and positioning the needle to a known position. Does anyone have any details on this?
Thank you
Thank you
