302 oil pressure sending unit failing
  • 302 oil pressure sending unit failing
    Baffles me. First unit I bought (store brand $12 autozone) was installed and it gave me a reading. Then it stopped hours later... Today I replaced it with a Oreilly's store brand BWD $12 unit and on first start up it worked. I killed it cause I realized I had forgotten to re-install a spark plug wire. After connecting (~1 min lapse), I cranked her up. No oil gauge... These electric sending units prone to shitting on you so easily? Is there's common fix for this? Very frustrated seeig how this is 2 units in 3 weeks.
    Ground the wire to test the guage.
      I had the same problem with my autmoter electric oil presure gauge. After about 4-5 sending units, I just replaced it with a mechanical unit, problem solved.
      Vortex rear stand $75
      8.8 410s. $50
      **SKAGG NASTY**
      1990 Foxbody GT for that ass
      11 4 door
      13 FX2 White 5.0
        Ya sorry I forgot to add that. I have done that. I know it works.
        Trying to avoid that. I already had to put an outside tach on the column. Idk where I'd put a single oil pressure.
          My factory gauge is acting up as well. If you are having this much trouble out of oriley electronics, then I will just go to napa.
          2005 M3 Vert with TSW rims
          2012 Ford Edge
            no oil pressure when warm? verify pressure with a mech gauge
              i had no radio so thats where i put mine.
                I does. I thought the same "oh shit" moment. Hooked up a mech gauge and I had plenty of pressure.
                  That is always a scary moment, when it goes to 0 and you are killing the car, yelling oh shit, oh shit. My gauges have seen better days in my coupe I ended up putting a mechanical water in the car, because it never went past 1/4 of the way. PM me if you want some ideas on a cheap but good route to go with aftermarket gauges.
                  2012 Ford Edge
