Has anybody had an issue with setting the tps sensor close to 1.00.Mine seems to have low voltage and cant get the dame thing set.
What does it read at WOT? Should read 5v.
At idle (zero throttle input) it should read no higher than .96v. If you can not get it down you may have to open the two holes so it will twist further.
