power trax vs detroit true trac or Lsd
  • power trax vs detroit true trac or Lsd
    My car is spinning only one wheel and im debating on either 3 listed for a rebuild. I can either just get new clutches and save alot of money for awhile but later on they will wear out again or i can go with power trax or detroit true trac but have never experienced other then Lsd. I daily drive my car and will be pushing around 900whp soon. I wouldnt mind a little clunking or noise. If anyone has had good luck with power trax or detroit true trac advise appreciated.
    440-RWHP, 400-TQ, 6psi
    7.4 @ 93 mph 1.7 60ft
    I have the True Trac in the GTO and it seems fine. I drive the GTO alot, and like I stole it and I didn't want to have the clunky of a true locker.
    John bought the True Trac set up after I got mine and he hasn't had any troubles either
      I've used posi's and LSD's and Like them both. I've got a practically new Auburn pro 31 spline posi sitting around doing nothing if you are interested.
        I love the trutrac, really solid feel and has proved strong so far.
          <------ has a TrueTrac and couldn't be happier.
            Sounds slooooow!
            Awwwwww skeet skeet skeet
            03gt intech POWA!
              I just ordered a true trac for the truck.
              You might also want to search for "value trac". They are made in the same factory using the same tooling, but are branded a different name, cheaper too!
              Ded
                detroit true trac
                I went with the detroit true trac. Thanks for your help. I hope it holds up.
                  Got true track installed and it drives like stock but with alot better traction.
                    i was gunna say the auburns are junk from my experience
