turn signal.......???
  • turn signal.......???
    ok so this one has got me stumped.
    turn signals work.
    on the outside..... just replaced the stalk switch and flasher relay.
    but heres the issue, the left turn signal on the cluster doesnt blinker....blub has been swapped out but still nothing.....and cluster has been swapped has well.......where to go from here.
    The outside lights flash or just illuminate?
      out side lights flash like normal. both on turning or with hazard pushed.
      just worried i might fail inspection since it doesnt flash on cluster.
        have you checked the plugs in the back of the cluster to make sure they are secure?
        Here's some more info on the subject, with some wiring diagram links too.
        I have a 93 coupe and the blinkers and flashers are inop. I can put power to the wires at the multifunction switch on the column and the lights light up but they don't flash. Could someone send me a wiring schematic for the system. Thanks. josh_mcbroom@yahoo.com
          got it....the blub holder for it was messed up swapped with different holder and got it.
