2004 Dodge electric problem
  • 2004 Dodge electric problem
    Having trouble with headlights working, changed the bulbs and still not working! Any ideas? It is a crew cab hemi if that helps at all with 118,000 on the ticker.
    Wanna see my care face???
    Fuse?
      Most likely the front controll module is fried. Are you running aftermarket lights? If so then that might be your issue. Seen it several times.
        They are Ultra highbeam lights.
          It is only the driver side headlight that is having issues.
            Does it have the integrated fuse box behind the drivers headlamp (it runs down at an angle from near the fender towards the motor rather that being flat with a lift off cover). These are notorius for failure, it runs independent lamp drivers for each lamp and beam meaning if that particular driver fails then you loose that specific lamp such as drivers high beam only.
            Fuse box like the one with red cover in pic
              No it's flat.
                check for power if you dont have any it the fuse box
                  Power is there. The bulb is good because it works in the passenger side.
                    Bad ground?
                      High beams work on that side?
                        Check for a bad fuse, lot of newer vehicles have a fuse for each lamp and beam
                          front control module or fuse box
                            it's at the dealership now, I came to the FCM as well, oh well, I would think that it wouldn't be having this problem already!
                              already? the thing is 8yrs old! LOL
                              they were bad about FCM's back when they were fairly new. I'd say you got a good life out of it!
