Possible broken ring? Shooting oil out pcv.
  • Possible broken ring? Shooting oil out pcv.
    Ran the pcv valve open and after this last pulley change its spraying oil out and smoking all over the Place. What's really odd is that when the oil cover is open it puffs smoke ( exhaust? ) I've got a vid coming. Power has dropped off too.
    2012 GT500
    Yup, sounds like you popped a ringland or two. A compression test would tell you a lot right now.
    01 red GT - 745whp/780wtq Whippled 4V and built 4R75W
      yup shes gone. melted piston/busted ringland. you got my number call me
        just curious , how many miles are on your cobra ?
        I sprayed 175 shot to my daily driver 97 cobra for a long time. Hell I had a 96Gt with 175,000 with a Novi and 11psi and never had any trouble.
        07 GT500
        05 SRT10
        88 turbocoupe T-bird
        93 Cobra
        86 coupe
        Ducati 848
          130k
          2012 GT500
            130k
            Damn that sucks man. At least now you can upgrade and crank up the boost.
            07 GT500
            05 SRT10
            93 Cobra
            86 coupe
            Ducati 848
              Are you saying you removed the line from the pcv valve and left valve open and its spraying oil?
                There's a built 4v up there 500 miles $3,000
                  Were you running a pcv on a supercharged engine?
                  Full time ninja editor.
                    Nope. It was just open
                    2012 GT500
                      first off, you shouldnt run it "open" but with a baffled breather, if anything. An improvement on that would be a breather with a catch-can.
                      It's a lot of crankcase pressure NA. Toss boost into the equation and its 10x worse.
                        12 lbs of boost on stock short block + cooler weather = bye bye ringlands. Bet you beating on it when it let go.
                        2012 SRT8 Challenger 392 Hemi-6 speed
                        Speedlogix Catch Can
                        Resonator Delete
                          It kind of gradually let go.
                          2012 GT500
                            Video will help
                              Originally posted by shumpertdavid View Post
                              Video will help
                              Link is in the first post. Its definately hurt.
                              Doug
                              90 LX Coupe 5.0
                              90 7up Vert. 5.0
