Almost done compiling parts for my build. It will be my first remote build, but not my first turbo.
Have
76mm (not really 76mm) mp ptrim.
prc springs/retainers
6ft 3.5" tube
12ft 2.5"
lots of 2.5 tbolts and silicone
big transcooler
detroit true trac diff
2 5/8s autometer cobalt boost and oil/ 3 pillar pod.
.5psi check valve
aem WB
walbro 255s
Need
china BOV and waste gate
big injectors for e85 (not sure what size, maybe 75lb)
HP tuners tune
MAP sensor
3800 stall
diff install kit/wheel bearings/seals
china cooler
I want to order my scavenge pump today, but I'm unsure on the brand.
I've been looking at turbowerx and rbracing. I just need something with a high continuous temp rating. I got a .5psi check valve to stop oil bleed to the turbo when the pump is off. I was thinking of doing a dedicated oil system for the turbo or some sort of oil surge type tank.
I plan on routing it back to the oil fill for ease like this.
Anyone have any advice?
I just need to get a new welder and some misc. crap.
I expect to be in the $3600 range after the build, including tuning.
Oh, this is the truck if you haven't seen it and the goal is 500+rwhp untouched long block.
This is the build I'm copying BTW.
Here's where I'm getting oiling info.
Have
6ft 3.5" tube
12ft 2.5"
big transcooler
.5psi check valve
aem WB
walbro 255s
Need
HP tuners tune
MAP sensor
3800 stall
china cooler
