Trickle Chargers and Optima batteries....
  • Trickle Chargers and Optima batteries....
    The Optima instructions say to make sure your charger is safe for AGM batteries. I always keep a battery tender hooked up when I am not driving my 65. I have searched and can not find out if the battery tender is safe for Optima batteries.
    Does anybody know?
    I have the Battery Tender Plus 12 V 1.25 Amp.
    www.dfwdirtriders.com
    Probably depends on which battery tender/trickle charger you have..
      Added.
        6. Use Battery Tender® Junior and Plus Chargers for charging
        lead-acid batteries only. They are not intended to supply power to an
        extra low-voltage electrical system or to charge dry-cell batteries.
        Charging dry-cell batteries may cause them to burst and cause injury to
        persons and damage to property;
        INFORMATION NOTE ABOUT DRY-CELL BATTERIES:
        There are some wet, non-spillable, lead acid batteries on the market whose
        manufacturers' make the claim that they are dry-cell batteries. These batteries
        are sealed, gas-recombinant, starved electrolyte, possibly with AGM
        (Absorbed Glass Mat) type construction. It is perfectly safe to use Battery
        Tender® Junior and Plus Chargers to charge these types of batteries. The
        dry-cell battery warning is intended for rechargeable or non-rechargeable
        alkaline and other similar types of batteries. If you have any doubt about the
        type of battery that you have, please contact the battery manufacturer before
        attempting to charge the battery.
          Vortex rear stand $75
          8.8 410s. $50
          **SKAGG NASTY**
          1990 Foxbody GT for that ass
          11 4 door
          13 FX2 White 5.0
            Thanks.
              I have used one on my Cobra with red top for 5+ years.
              Most people wait until the battery is low/dead before trying to maintain it properly. If the battery has been low already, it may be too late to save it. You want to ALWAYS connect the maintainer when you are done using the vehicle not 2 weeks later.
                Hearing from others that they have done it with success makes me much more comfortable. These Optimas aren't cheap.
                  I need to find out what battery charger I have. I just bought a red top too
                  8.8 410s. $50
                  **SKAGG NASTY**
                  11 4 door
                  13 FX2 White 5.0
                    If you go down to about the 14th post they start talking about battery tenders and Optima batteries.
                    My 94 cobra sits quite a bit and even longer over the winter. After it sits the computer eventually drains the battery, so then I would unhook the battery and recharge it. But then when I reconnect it, the computer has to relearn the cam etc. over time again to idle right. I found a awesome...
                    '93 Cobra-Coyote Powered
                    '13 Dodge Cummins
                    '14 Rubicon X
                      I have the one I posted in your other thread and it has worked flawlessly for over a year on my red top. One time I even let it drain down to nothing, did the optima recharge (hook it up to a good 12v non optima battery and a charger) then put it back on the trickle and it seems as healthy as ever.
                        genius chargers are great to have if you ever wanted to get something different then the old battery tender
                          http://forums.corral.net/forums/5-0-...-sits-lot.html
                          ...and where the AGM battery is called gel and where the output of the device is said to have something to do with what kind of battery you have instead of what the load on the battery is, etc
