Im at a loss. Has a miss when running, narrowed it down to the #7 cylinder by pulling the plug wire and noticing no difference in idle or reving, also pullled plug and it looked a little wet, but didn't smell like gas, possibly oil. Compression test showed 150psi. Also checked temp of manifold coming out of that particular cyclinder and its ~200 degrees cooler than the others. Just changed out the fuel injector, same issue. Checked continuity from the injector wire all the way back to the ECM plug, both wires are good. What else is there?!
87 GT btw, the non-HO version for some reason if that matters.
