99 Explorer losing coolant
  • 99 Explorer losing coolant
    My mom's V6 99 Explorer is using/losing coolant enough to require adding a pint - a quart a week or so. I couldn't find any leaks. It doesn't seem to be the heater core either. That leaves the intake or a headgasket? It doesn't white smoke on start up or running that I can see. Is there a common problem area for these that I should look at first?
    mine was head gaskets. heads are prone to cracking on those too. I put an engine in mine.
      triple check the t-stat housing...do you have a pressure tester??? if not, I'd spend 30 or so dollars before you waste money
      _____________________________________________
        if its an e vin, yes, check the t stat for sure. I agree with the pressure test.
          You should be able to get a kit cheap to check for gasses in you coolant at autozone.
            those combustion gas testers got high as fuck here recently...
              napa BK 7001006
              42.99
                The thermostat housing was cracked. It's a big relief for her because she can't really afford to do a major repair or get a new car right now. Thanks for the advice.
                  my 91 is doing the same thing so im selling it for $500 so some tech can fix it and flip it for some cash,....
