Problems after a tune-up. Need help.
  • Problems after a tune-up. Need help.
    So, if I drive the 2000 expedition for 1/2 an hour, it will start to sputter. More at higher speeds and seems to be on inclines. Previous computer diagnostic said there was a misfire in 3. Replaced coil pack in 3 and it's still doing it. Can a brand new spark plug be defective? It is some cheap ass auto zone shit. I'm going to go have codes checked again tomorrow. I like to figure this out before Friday, so my sister can drive it to Texas for Christmas.
    TIA for any and all help.
    It doesn't sputter unless driven for a while. Nothing will happen in 15 minutes. About how long it takers her to drive to work.
    Maybe your porcelain's cracked. Pull the plug.
    -'89 Half-real Saleen with a belt squeak
      bad Intake manifold gasket or vacum leak can make it misefire.
        Did it do the same thing before AND after the coil pack was swapped ?
        Did you change ANYTHING else, other than the #3 coil pack ? Spark plug ?
        Did you replace the plug only on #3 cylinder ? If so, did you gap it to factory specs ?
        How many miles are on this vehicle ?
        -Aaron
          Did you change ANYTHING else, other than the #3 coil pack ? Nope Spark plug ? Nope
          Did you replace the plug only on #3 cylinder ? If so, did you gap it to factory specs ? Yes, if I recall it was .54
          How many miles are on this vehicle ?129k I believe.
          The first cylinder on the drivers side closest to the radiator we got a new fuel injector for.
          Fixing to go to Autozone to check for codes.
            You lost me there. So you DID change one plug ? You also said you've got a new fuel injector for one cylinder....has it been installed yet ?
            Do you know if all of the plugs and wires/coil packs have ever been changed on this vehicle yet ?
            -Aaron
              -Aaron
              Sorry, I changed all the spark plugs and gapped them. I got a new fuel injector cause the boot/seal/fitting at the bottom of the old one cracked and no one sold replacement boots. I did install it as well.
              Since the sputtering started I have no replaced the new plug I installed.
                Isn't .54 a bit wide?
                Full time ninja editor.
                  .054, hopefully. But, even then.
                    Exactly.
                      should be somewhere between .052 to .056
