Well I think it is time that I start gathering parts for my 89 GT. I have seen numerous posts on many different forums, and had many discussions with people about the Ford 302.
I currently have the following mods:
GT40P Heads
Explorer Intake
Cold Air Kit
75mm TB
B Cam (So I Have Been Told)
I am going with a 'Economy' shortblock and putting all of the above back into it. However, I am thinking about switching the cam since I think the cam bearings are wore out on my car.
I am going to put a Vortech on the car and run between 9 -12 PSI. What cam would be a good match with the heads that I have? I will not be milling them down while they are off the car and the shortblock is about 9:1 compression ratio.
Here are the items that I will be getting in order to get the car freshened back up:
MOTOR MOUNT TO BLOCK BOLTS
4 PIECE OIL PUMP BOLT KIT
HEAD BOLT KIT
OIL PUMP DRIVESHAFT
INTAKE MANIFOLD BOLT SET
OFF ROAD H-PIPE FOR LONG TUBE HEADERS
BBK CHROME LONG TUBE HEADERS
THROTTLE BODY GASKET KIT
OIL PUMP PICKUP TUBE
FUEL INJECTOR O-RING & PINTLE CAP KIT FOR EV1 BODY 19lb INJECTOR
HEAD GASKET SET, M-6051-A302
HYDRAULIC ROLLER LIFTERS, M-6500-R302
HIGH VOLUME OIL PUMP,M-6600-D2
HEADER GASKETS,M-9448-B302
GT40/COBRA UPPER INTAKE GASKET, M-9486-A50
MG-5835 86-95 MUSTANG 5.0L INTAKE MANIFOLD GASKET SET
HIGH ENERGY HARDENED PUSHRODS,5/16"x 6.25", SET OF 16
PRO TIMING COVER & WATER PUMP GASKET SET
WATER PUMP & TIMING COVER STUDS & BOLTS
SPARK PLUG WIRE SET
1-PIECE ENGINE OIL PAN GASKET
302 ECONOMY SHORT BLOCK, ACCEPTS ROLLER CAM
OIL PAN DRAIN PLUG GASKET
Is there anything else that I may need?
Thanks for all the help!
GT40P Heads
Explorer Intake
Cold Air Kit
75mm TB
HEAD BOLT KIT
OIL PUMP DRIVESHAFT
SPARK PLUG WIRE SET
