Its always hard to say with these cars and I don't know the compression so that doesn't help. I thought 310 315 was healthy assume the valve job on the heads was good and the compression is decent
Na probably cheaper than most think. Just try to determine if I want to part it out or sell it whole. I'm going to list it after I've bathed it and taken good pics. Welcome to pm offers. I bought it to sell after all
So I'm about to get off and mess with the car. I'm going to drain the gas 1st. Then pull the plugs and spray the shit out of the cylinders with wd-40 thru th spark plug hole. Replace with new plugs and then put fresh gas in. Then I will disconnect the wire to the coil and then crank it a bit to use the starter to turn the motor over. Then reconnect the coil wire and fire it up.
